Power outlet on dash not working
Is there any other fuse besides the one behind the coin tray in drivers side?
Didn't want to go tearing into the dash to get to the back of the lighter socket only to then find out there was another fuse somewhere, so asking here just in case there is possibly another fuse elsewhere.
Just getting tired of reaching into back of console to plug phone charger and hope to figure it out...
What else is not getting power also will give you a clue.
Typically the large fuses are upstream [engine bay next to the battery] and then branch fuses are in the kick panel. The upstream fuses if blown will cause extensive black out and if only the cig-lighter is of, then it is a local problem. I hate cig lighter driven accessories as they are based on slip pressure to make contact and after a while the connection is not solid.
Salim
Salim
