2000 RX300 - P1354 but Only 2 Cylinders Misfiring (P0304 / P0306)
I have an 2000 RX300 that has the following codes appear intermittently:
I have gone through all the P1354 threads associated with multiple cylinder misfires, and all had the entire bank of cylinders misfire.
Any thoughts on what could be causing only 2 of my cylinders to misfire?
- P1354
- P0300
- P0304
- P0306
Bad coil-pack, bad plugs .. Have you tried swapping things around .. suspect with know good.
Once you get passed the swapping test, I would investigate with compression test/valve leak down.
Salim
Salim
bwilmoth
RX - 1st Gen (1999-2003)
01-17-12 11:34 AM
Nuckingfut
18
10-25-09 05:29 PM
