Replaced dogbone to stop low end vibration-only partial fix
I replaced the dog bone (99 RX300AWD) as it was definitely bad. It helped low end vibration under load, but there is still some. I have cleaned carb and MAS, and think it might be the lower mount needs replacing too. I have part number from another post 12361-20060, Is it a big job to get at, and are there 2 parts you can buy as an assembly, or easy to insert new bushing? Thanks!
[QUOTE=reedsrx300;9791307]I replaced the dog bone (99 RX300AWD) as it was definitely bad. It helped low end vibration under load, but there is still some. I have cleaned carb and MAS, and think it might be the lower mount needs replacing too. I have part number from another post 12361-20060, Is it a big job to get at, and are there 2 parts you can buy as an assembly, or easy to insert new bushing? Thanks!
Could you show picture of your old part vs your new part?
SuicidnS13
03-23-13 01:52 PM
sonyman
27
09-29-07 10:46 PM
