RX300 blowing "Gauge" 7.5 fuse after using key to open windows
I have a 2002 RX300 AWD that I just purchased the other week. Everything was working fine, until I lost power to the windows, A/C and the "highs & mids" of the stereo. Weird.
I know this may be a shot in the dark, but has anyone experienced this....
Strereo details: I have power to the radio & CD player. It displays on the HUD. I can also hear the bass/lows if I crank the volume. Highs & mids are absent.
A/C details: the a/c used to work great. Now there is no power to the controls, nor any display in the HUD.
Windows: the windows worked, mostly. The RR was wonky, and I could see discoloration on the master controller board. A replacement arrives Monday. Now, NONE of the window switches work!Possible Cause: I used the "open windows with driver-side key" feature. The windows started going down and stopped about mid-way.
Troubleshooting: I noticed the #16 "Gauge" fuse in the "Instrument Panel Junction Box" was blown. It blew immediately after trying to replace it.
Much thanks in advance!
Welcome to Club Lexus.
Please try to avoid acronyms in your posts. Filter/language_checker tends to flag the post as inappropriate.
Salim
Salim
If youre blowing a fuse immediately. That means you have a dead short. Easiest way, is to get a wiring diagram, find the circuit which is blowing, and what all components it feeds. Then you need to isolate each item one at a time. You can either use fuses, or if your familiar with a volt ohm meter, use it to let you know when you've isolated the offending device. If you disconnect all devices, and still have the short, then you've got a wiring problem. Which if it has to do with door stuff, id be willing to bet the problem is in the doors, either a burnt switch or where the wire comes through the bulkhead from the car to the door.
Rollaboy
08-17-09 05:14 PM
gotparts?
07-18-07 05:51 PM
