How to remove map light housing?
Also known as overhead console.
From memory:
Make sure the key is out of ignition for say 5 minutes.
Disconnect battery ground terminal.
Remove the clear plastic cover to access the dome lamp.
There should be 4 phillips screws holding the overhead console to the body.
Salim
From memory:
Salim
