Alarm system
I am replacing battery and now after all this time, the alarm goes off. I only have Manuel key. I pulled the horn fuse. This is a 2000 and please help me crank it or can I boost or what
I have replaced battery many times but never alarm
Which battery? 12v battery or the battery in the car key (remote).
Salim
Bought new battery for trucking( battery that goes under Hood, I guess l2 v). Now truck thinks it's being stolen and alarm going off. I pulled horn fuse,so what next? I only have manual key to door. Do I just find fuses and pull for Hazzard and lights? Truck is old but never has alarm activated when replacing truck battery.
Disconnect the battery 12v and reconnect after 30 mins.
Once you reconnect, use your key and insert in ignition. You may have to turn ignition to run position.
Hopefully the alarm system will reset.
Salim
Salim
Tom326
ES - 6th Gen (2013-2018)
02-20-18 10:51 PM
GsLex00
02-27-16 12:10 AM
