Front metal clanking noise going over bumps.
When I had it up on jacks a while back, with hands on 9 and 3 I could move the driver front wheel. But I don't suspect bearing (yet) because I don't think ettatic pulling is a symptom and also there is no bad bearing sound. Also, it is a pretty expensive procedure :-/
Bearing play will be at all locations. 9-3 only is steering link [tie rod ends or the whole rack]
Salim
IMHO you are overthinking the problem. I would recommend going to a suspension place and let them diagnose.
Salim
Metal clunk going over speed bumps is:
1. bad sway bar bushings. #1
2. loose piece of metal in the trunk that is heard in the front. yep, it's a large resonating metal box
3. power train mounts.
4. loose exhaust pipe
9-3 is most likely tie-rod and rack.
12-6 is likely control arm or ball joints.
Both of the above are very easy to check by suspension place.
9-3 & 12-6 on the same wheel may be bearings. The bearings are less likely as they are not the cone type.
Salim
Salim
Salim
Salim
