?Where is Fuel filter located?
In the fuel tank where the fuel pick up is.
Check for fuel pressure and fuel volume delivery from the pump before trying to replace the fuel filter.
Salim
Salim
Salim, Is the sock filter in the tank the only filter for the entire fuel system? I have a 91 Deville and there is the sock in the tank but also I have a canister filter under the car to do fine particle filtration. Thanks!, Sean
If you suspect fuel delivery problem, most likely it is the lift pump n the tank. Fuel in USA is typically free from junk and the tanks do not rust any more.
Salim
