Speaker Replacement Recommendations
Hello,
I am interested in replacing the speakers on my 2000 RX300. I do not have the Nakamichi system.
What speakers would you recommend and what are the specifications I need to look for?
Thank you !
Thank you !
try posting in the special interest Audio forum.
Also list your objectives.
Salim
Salim
Any speaker is only as good as power supplied to it. I replaced many speakers and finally learned to replace the source of signal, supplied to speaker. Unless speaker is torn and has to be replaced. Otherwise, it's more of wishful thinking than real improvement.
As of fancy brackets required, I simply drill holes in door panel to match new speaker and bolt it on. Maybe run some adhesive insulation strip, few bucks from any home improvement store, to avoid rattles.
Chexation
GX - 1st Gen (2003-2009)
01-17-19 04:47 PM
