Help Needed : Air conditioning problems
Hello everyone. My chairot is a 2002 Awd. I recently did a complete air-conditioning work: changed the compressor, condenser and evaporator. Blows cool air too.
I stay in a place the outside temperature gets up to 34 degrees Celsius I had to set the air conditioning temperature on the lowest.
But I recently noticed that after the ac is on and cooling for about 15 - 20 minutes, the amount of air is greatly reduced and it brings out a kind of mist from the vents. If I switch the ac off and powers it after about 5 minutes it blows right amount of cool air and does the same thing after few minutes.
I contacted an ac mechanic, he tells me there is a kinda thermostat on the evaporator and that it could have failed. And that it could be forming ice or so.
Can someone help out with possible causes?
Thank you.
Thank you.
Jlacck
09-05-15 01:57 PM
