Oil leak and/or high consumption?
Old 08-14-18, 10:52 PM
  #61
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Originally Posted by trhs75
That's what it sounds like to me also, Salim. I have wondered if cleaning a V1 valve cover would help the problem, but I agree with fastnoypi that it seems simpler (although at a $200+ cost) to just put a new valve cover on instead.
We need to then add miles to the 2nd/3rd gen valve covers, before saying the newer valve covers solve the oil consumption problem
Salim
Old 08-15-18, 06:58 PM
  #62
trhs75
trhs75's Avatar
You're absolutely right, Salim! I think I have read on this forum that it has done the trick for some owners; I hope it works for my RX.
Old 08-15-18, 09:52 PM
  #63
Lexmus
Lexmus's Avatar
After replacing my 1st gen with a 3rd gen cover, I doubt I could have cleaned the 1st gen cover well enough to approach a new one. Plus, given the money saved on the labor by replacing it myself, and given Lexus had redesigned it, made it sensible to install the newer version cover. And having to do that job again if a cleaning didn't work was not something I would have wanted to face.
Old 08-16-18, 08:56 PM
  #64
trhs75
trhs75's Avatar
I took a stab at cleaning the old valve cover; I figured why not? There's still a lot of crud on it, and I know it has to be caked on between that black plate and the aluminum cover. I think it would have involved more than $200 of my time just to clean it!!
Old 08-16-18, 10:08 PM
  #65
salimshah
salimshah's Avatar
For those who replaced the valve cover, please do all of us a favor. ..
Log the milage at which you noticed oil consumption. Log the same amount of milage with the replaced cover and report if they are seeing oil loss through the valve cover.
Salim
Old 08-17-18, 02:37 PM
  #66
trhs75
trhs75's Avatar
Good idea -- I will report after my next highway trip!
Old 08-20-18, 08:43 AM
  #67
Dukenukemx
Dukenukemx's Avatar
Originally Posted by salimshah
Let me understand this bit better ..
when you say you did "this" ... do you mean you took the first gen valve cover and cleaned it up and and put it back and this reduced the oil consumption?
Salim
Yes. When I got the car it had consumed about a quart of oil in less than 500 miles. After I took off both valve covers and cleaned them plus changed the valve cover gaskets it consumed about 1/4 of a quart of oil within 500 miles. It took a days worth of effort to clean them, and I was left with a gallon of gasoline that was full of carbon that I had scrapped off. I ran the gasoline through a strainer and the bucket I used was still full of heavy carbon powder. There was some slug in the engine, but I just scrapped it off.
Old 08-20-18, 08:55 AM
  #68
owenstrawn
owenstrawn's Avatar
I first noticed unusual oil loss in our 2000 AWD RX300 at 138,000 miles, crossing west Texas at 85 mph in Jan 2013. But because we travel only rarely I didn't figure out what was going on until a couple of years later. Changing out the PCV and using Seafoam helped for a while but not for long. On our last trip with the original valve cover, we lost 9 quarts of oil in 600 miles.
At 218,833 miles, I replaced the original rear valve cover with a brand new 3rd generation 11201-0A060 valve cover (Toyota actually calls them cylinder head covers). Last week we spent 3 full days driving cross country, encountering 99 degree heat, 4,000 foot climbs (and descents), strong headwinds, and several hours of heavy 80 mph traffic (the kind where you don't dare slow down to the 65 mph speed limit).
I have found that if you want to know exactly how much oil you are losing, you need to check the level with the engine fully cold, and parked on level ground. If you check on the road (say right after gassing up) the level will be significantly lower than if you wait until the engine is cold (typically the next morning). Also if you park nose down on a slope the level will be higher than normal and if you park nose up it will be lower.
I had the oil changed the day before we left, and checked the level in the morning while loading up. It read around 2/3 from the lower button to the upper (parked nose down, engine fully cold). When next I read it after the first easy 250 miles (parked level, engine hot), it showed just above the lower button. With that disappointing loss I figured I needed to keep it topped off so I added a quart. In the subsequent 1,250 miles it didn't budge below 3/4 hot or right on the top button cold. So I suspect the initial "loss" was really just inaccurate measuring.
Gas mileage has also returned to levels I haven't seen in years. We got over 21 mpg on four of the six 250 mile legs. Climbing cut the mileage significantly though. I also thought it was interesting that I could tell when we were climbing because the water temperature bumps up to just over the mark (it's usually just under the mark).
What's the downside to this upgrade? Well, I am now feeling the need to fix some of the appearance items that I have let slide over the past 40k miles. It really is a very nice car.
Old 08-20-18, 08:56 AM
  #69
salimshah
salimshah's Avatar
edit .. snip
This is excellent information. Lets see how much oil consumption (hopefully none) that you observe after 138K miles with the new valve cover. The good this is you bought a new cover and it had '0' miles in use.
Salim
Old 08-20-18, 08:57 AM
  #70
owenstrawn
owenstrawn's Avatar
If this car makes it another 138,000 miles I will be astonished and highly gratified. But even if it does start burning oil again it is totally worth the $300 to fix!
Old 08-28-18, 06:58 AM
  #71
owenstrawn
owenstrawn's Avatar
Update: Arrived home after a second week on the road. Added 1 qt oil in Guymon OK (256mi) (but I think it was not properly topped off at the oil change). Dipstick showed full at Moriarty NM (555mi) & Tucson AZ (1000mi); ~1/8 qt low at Brea CA (1772mi), 1/4 qt low at Page AZ (2376mi), 1/3 qt low at Wichita KS (3416mi). Not bad for a 222k mi car!
Fuel mileage was only 20mpg overall, which is a little disappointing. FWIW, it was much higher in CO climbing Wolf Creek Pass than it was in CA traffic.
Old 08-28-18, 07:42 AM
  #72
Lexmex
Super Moderator
Lexmex's Avatar
What oil and weight is everyone using?
Old 08-28-18, 08:07 AM
  #73
owenstrawn
owenstrawn's Avatar
5W30. I used Mobil 1 briefly, but switched back to Pennzoil or Quaker State with the oil loss problem. I'm considering switching back to synthetic now that it is resolved.
Old 08-28-18, 10:29 AM
  #74
salimshah
salimshah's Avatar
I am confused now ,,,
Did the new gen3 valve cover .. was your oil consumption imrprove or just simply reduced?
Do you attribute the oil consumption to the path through the PCV?
Catch can would surely tell if oil is coming through the PCV.
Salim
Old 08-28-18, 11:01 AM
  #75
owenstrawn
owenstrawn's Avatar
My oil consumption went from 9 qts in 600 miles to 1/3 qt in 3400 miles. Which is good enough for me.
I believe the 9 qts was PCV and the 1/3 qt is natural for a 222k mile engine.
Quick Reply: Oil leak and/or high consumption?
