Door unlock FOB options
Yes, ask your Dealer to use the Scantool to change the setting from Driver's Only to All Doors.
The point of the default setting is for security when you travel alone and unlock the driver's
door the other doors don't also unlock and let a ruffian jump in.
Later Lexi have customization menus but I could not find one for your generation.
If you have misplaced your Owner's Manual you can do as I did and log onto
www.lexusdrivers.com and select model and year. Then go to the top tabs and
select "Resources" and find Owner's Manual. Download the PDF and check it out!
No, I would not state it like that. The question is are you willing to pay the dealer for time/labor? The tool may be available from knock-offs and even some shops may have purchased/leased it from Toyota.
Salim
Salim
