RX300 Brake Pads Replacement Cost
Old 07-01-18, 01:29 PM
Mystery
Mystery's Avatar
Question RX300 Brake Pads Replacement Cost
I checked online estimator and it says brake pads replacement is around $400.
The average cost for a Lexus RX300 brake pad replacement is between $396 and $416. Labor costs are estimated between $70 and $89 while parts are priced between $326 and $327. Estimate does not include taxes and fees.
Is the part that expensive? $326?
I checked autozone, aap etc and they are $35 for all 4 pads.
Also, how hard is it to do yourself?
Old 07-01-18, 01:39 PM
maxSteel
maxSteel's Avatar
Nothing special about doing Lexus RX300 brakes.
Maybe that parts quote includes new rotors, pads, and hardware purchased from a Lexus dealer.
Old 07-01-18, 01:42 PM
salimshah
salimshah's Avatar
Received 1,078 Likes on 970 Posts
What else needs to be done? Is it the pads are worn and there is no damage to the rotors? Do you feel pulsations as apply brakes?
Replacing pads is very easy. You just need the know how and couple of tools. The DIY [and even any repair] can take the turn for the bad. Search the DIY thread
Salim
Old 07-01-18, 01:48 PM
Mystery
Mystery's Avatar
Salim
If the labor is less than $100, I prefer to pay to mechanic.
I feel some pulsation/vibration on the steering wheel when braking sometimes.
Is that bad brake pads or drums?
Old 07-01-18, 07:25 PM
salimshah
salimshah's Avatar
Labor is based on time and additional tasks. If the rotors have to be removed and turned and reinstalled the time and another trade comes in. Expect to pay anywhere from 300 to 500 for a complete brake job.
If pads are the only things that need replacement, it can be done in an hr. I usually purge my brake lines too. Rear pads usually last 2 to 3 times longer than the front. You can price the pads. Since the labor is my time [DIY] I divert the money to OEM products.
Brake jobs are done by so many shops, you can shop around.
If you plan to DIY, make sure it is not your first project. Get some help/guidance.
Salim
Old 07-02-18, 01:41 AM
artbuc
artbuc's Avatar
It all depends on what is done. Is it a complete job done correctly (OEM quality pads, new hardware, caliper brackets cleaned and lubed, caliper slide pins cleaned and lubed and visual inspection) or is it is a simple “pad slap” using cheap pads? Labor seems low for a high quality job and parts are too high for any job unless it includes rotor surfacing. High quality pads such as Akebono Proacts will be $30-40 per corner and add another $20 for new hardware (some applications include new hardware).
Old 07-02-18, 12:58 PM
Mystery
Mystery's Avatar
Thanks for replies.
I don't have skills nor tool to do it so I'll get a mechanic.
I also checked yourmechanic online quote and they are much cheaper at around $134.
Has anyone dealt with yourmechanic?
YourMechanic Price
$114 to $134
Labor: $70 -$90
Parts: $44
Old 07-02-18, 09:34 PM
salimshah
salimshah's Avatar
Thanks for replies.
Not a bad call [although I encourage folks to DIY].
Please do not make the mistake of deciding based on cost.
Right fix would be determine what needs replacement.
Then determine the parts and labor.
If you go with the first quote ,,, it might be based on least parts and fix [slap the new pads].
Expect the mechanic to call you and then add the needed parts and labor. Some unscrupulous may up-sell and push un-needed work. Hopefully you will be going to a sound place. If they find some thing, would you pass or get it done. Many places always include turning the rotors when they quote.
Salim
Old 07-03-18, 09:28 AM
Mystery
Mystery's Avatar
Salim
At this point, cost is the main factor.
Due to this car's age and value, it doesn't make sense to pay half of car's worth on every issue it has.
I just want to repair it so it doesn't die on the way to work.
It's only used and will be used as in town car.
Carmax quoted it for $1400, same cost of replacing the knock sensors so the more money I put in, the more loss I'll take.
Old 07-03-18, 03:14 PM
ukrkoz
ukrkoz's Avatar
Find a buddy with hand skill and tools. Buy pads at Autozone, 2nd from the bottom in price. Don't buy ceramics or organics. Get semi mets. Buy tube of caliper grease.
It's 20 minutes per side job and 2 wrenches plus jackstand are needed. Case of beer if buddy with skill is a male. Done. Total cost will be about $60, I figure, depends how expensive beer is.
Old 07-04-18, 01:24 AM
artbuc
artbuc's Avatar
Mystery, did you ever replace your AF sensor and/or do the knock sensor hack?
Old 07-04-18, 10:15 AM
Mystery
Mystery's Avatar
Yes, updated the main thread.
Good so far on the knock sensor hack.
Old 07-04-18, 02:12 PM
Lexmex
Super Moderator
Lexmex's Avatar
This thread brings back memories of all those DIY brake jobs I did on this forum.
mikek753
06-27-19 10:33 AM
vinster29
48
10-17-17 11:55 PM
lexrally
13
07-15-15 01:18 PM
lexrally
11-07-11 08:29 AM
GOT LEXUS?
20
05-13-05 04:41 PM
Quick Reply: RX300 Brake Pads Replacement Cost
