Power steering suction hose
I noticed the power steering suction hose has fairly deep cracks, but it is not leaking yet. I looked up the OEM part and it is $125 discounted. Can I just use transmission hose to replace it?
The suction hose connects the reservoir to the pump, but it isn't under high pressure. The transmission hose I have is rated 300 psi.
The last time I replaced hoses and pump was for a 2003 Sienna 3.0L. The pump is buried deep into the engine and I believe that all the hose were formed hose. As Salim has suggested try a pick n pull yard and look for both Lexus and Sienna or any other Toyota of that year. The hardest part of replacing the pump was removing the high pressure from the pump. It uses a banjo bolt, but Toyota decided to stick a sensor on top of the banjo bolt and you had to remove the electrical connector to the sensor blind.
Gong by memory there are two hoses to the reservoir. One is the feed and the other is the return. The return has a pressure reducer in the hose, so make sure that you do not use pipe without the pressure reducer in the return.
Salim
Salim
I will also take a photo of the hoses and post.
Found hack hose
This hose a bought on Amazon for about $9 it's for a Nissan but I just cut the excess length and it fit perfect no kinks at all. Hope this helps a few of you and save money.
Tau511
Performance & Maintenance
02-23-16 06:43 PM
Blaizze
04-25-07 01:38 PM
