Front Vanity/Dome Light Length?
Does anyone happen to know the length of the bulb needed? I know the bulb model is DE3175, but there are different lengths, can't seem to find that information.
I just measured the map light: the bulb glass length should be no longer than 24 mm, the bulb overall length should be no longer than 43 mm (based on plastic housing space).
When I replaced all DE3135 with LEDs, I had the same question, so I measured it compared to LED dimensions most website would provide. This type of bulb has more plays in dimensions than other types. A little off is not a problem. In my other cars I had to bend the bulb terminal holder a bit to fit bulb in.
gookies (11-04-18)
Vanity bulb measured: overall length = 29 mm, glass part length = 15 mm, diameter = 6.2 mm. I don't know the bulb part number, says Type E in the 2000 year manual. I will try to find LED bulb for that.
gookies (11-04-18)
gookies (11-05-18)
I bought from aliexpress.com: https://www.aliexpress.com/item/10x-...84424c4dwhzQfK. Most are for my Honda Odyssey. It also fits in RX300 well.
LS430inDE.
05-27-19 10:32 PM
