Engine misfiring, jerking when accelerating - No Codes
Old 11-19-18, 01:34 PM
Jonwrench
Jonwrench's Avatar
Angry Engine misfiring, jerking when accelerating - No Codes
Replaced coils, plugs, filters, pvc valve, cleaned MAF and IAC units. All vacumn lines are connected, no leaks found. Engine idles fine, but when you accelerate the engine jerks and seems to misfire. Slow steady application of the throttle, then engine does better. No check engine indicator activity and no codes. Any ideas?
Old 11-19-18, 03:27 PM
carguy07
carguy07's Avatar
Plugged cat?
Old 11-19-18, 03:53 PM
Jonwrench
Jonwrench's Avatar
Makes sense, Its the original catalytic converter; any way to test for this? Have replaced all 02 sensors
Old 11-19-18, 05:12 PM
carguy07
carguy07's Avatar
You could take the exhaust apart ahead of the rear cat and push it to the side and drive it around the block. Would probably have your answer pretty quick if it was that one. The front ones would be a lot harder to diagnose, although you would think a pre-cat would throw a check engine light.
Old 11-19-18, 05:33 PM
Jonwrench
Jonwrench's Avatar
Sounds like a good course of action. Will give this a try and get back to you. Appreciate the prompt response.
Old 11-19-18, 09:54 PM
salimshah
salimshah's Avatar
Received 1,072 Likes on 965 Posts
May still be worth connecting OBDII reader to see if you have any pending code.
Salim
Old 11-20-18, 07:29 AM
Jonwrench
Jonwrench's Avatar
Thanks, just checked, no pending codes. Forgot to mention this unit has 226k on tt with all original exhaust components. Notice that there are leaks at the donut gaskets. Will start with replacing the front section and leave the middle and back alone since there is no leaks. Noticed that the center pipe, muffler and cat are all one piece. Checked on OEM parts, very pricy. Do you all know of a more reasonable priced alternative source?
Old 11-20-18, 02:35 PM
carguy07
carguy07's Avatar
Walker makes most of it. Rockauto is usually pretty competitive on price.
https://www.rockauto.com/en/moreinfo...373879&jsn=336
Old 11-20-18, 05:08 PM
Jonwrench
Jonwrench's Avatar
Thumbs up
Great, thanks so much, Rock Auto is much more reasonable. Will let you all know how it goes.
Old 11-20-18, 05:20 PM
ukrkoz
ukrkoz's Avatar
EGR. That's how it manifests. EGR and ALL plumbing to it needs to be cleaned.
Old 11-20-18, 05:21 PM
ukrkoz
ukrkoz's Avatar
Cat doe snot really give jerking. Gives slow loss of power, but it's linear. Car simply gets very sluggish.
Old 11-23-18, 03:31 PM
Nad1370
Nad1370's Avatar
Need to check fuel pressure.
Definitely not an EGR problem since the RX does not have one.
Old 11-23-18, 06:31 PM
Jonwrench
Jonwrench's Avatar
Checked and cleaned vacuum lines and metered the switches, all good. Will check fuel system pressure when I finish installing CATs and exhaust components. Really appreciate everyone’s responses.
Old 12-22-18, 10:59 AM
Jonwrench
Jonwrench's Avatar
Have replaced Cat Converters, has definitely helped the issue. Still has hesitation at higher RPMS. Slow steady application of throttle when in park yields smooth transition from idle to 3000rpm, then the engine hesitates, doesn't appear to be misfire, just cutting out. Throttle application can take it to higher rpm, but it runs rough and jerky. In drive the vehicle shifts fine through all gears when throttle is applied slowly and steady, however if you aggressively accelerate the problem returns. Idles fine, transmission seems to be fine too. Not sure how to check fuel pressure, but it seems to start and run fine, unless you are aggressive with the throttle.
Old 12-24-18, 02:08 PM
ukrkoz
ukrkoz's Avatar
But it's EGR like symptoms. So yes, indeed, VVT took over EGR function so maybe something is not right with VVT? Dirty strainer filters, failing solenoids?
Quick Reply: Engine misfiring, jerking when accelerating - No Codes
