I took the rear courtesy light bulb out.
All the courtesy lights, the centre VDU, and the remote locking stopped working.
Please will you kindly tell me how to get them working.
All fuses in each box are good.
Salaam alaikum Salim
Thank you for your rapid response.
The light was on.
The battery was connected.
As far as I know, I did not short the fuse.
I checked the fuses with an ohm meter.
The ohm meter was set to squeal if the fuse was good.
I also checked the dome fuse, and the ECU-1G fuse by eye.
The light was on.
You can try swapping the 'dome' fuse with another of same rating. You may even have a spare in the fuse box. The worst outcome is the new (or the swapped) fuse may blow if there is permanent short.
Checking by eye can at times give you wrong indication.
Salim
Salim
I waded all through the fuse pages (body electrics) in the maintenance manual Salim.
I could not find a fuse that was not in one of the two fuse boxes.
I can't work out why removing / shorting out a bulb on an ignition on or off circuit
will stop an ignition only circuit working .
Have you any idea how that can happen please
As far as the dome light goes have you tried a new bulb and have you tried the switch. you could put your voltage tester on the bulb connections and then try the switch to see of you have voltage. I can't imagine the dome light and the other items on the same circuit but I would start with what you did in the first place to see if it is the cause.
I would still insist that get hold of the circuit diagram and that will tell you where ALL non working components combine. You have to the trace upstream from that point. Generally Lexus does not use switching on the ground side and that makes troubleshooting lot easier.
If only the dome was out, then I would suggest unscrew the fixture and check if the connector is still attached. All connectors in Lexus have a locking mechanism, so it is very unlikely that the connector is loose, but some one may have been in there before you.
Salim
As far as the dome light goes have you tried a new bulb Yes and have you tried the switch. Yes you could put your voltage tester on the bulb connections and then try the switch to see of you have voltage No volts at the switch. I can't imagine the dome light and the other items on the same circuit but I would start with what you did in the first place to see if it is the cause. , I believe I've done that.
Dome circuit is live all the time, you have to disconnect the battery while working on it and accidents can happen. Yeah, a right plonker aren't I
I would still insist that get hold of the circuit diagram and that will tell you where ALL non working components combine. Please would you give me some help here please Salim )
I find the circuit diagrams maintenance manual exceed my skills.
Especially since I need to speak French, Soanish and German to get max benefit
Would you happen to know which pages I need in the manual please.
If only the dome was out, then I would suggest unscrew the fixture and check if the connector is still attached. All connectors in Lexus have a locking mechanism, so it is very unlikely that the connector is loose, Nothing loose in there thanks but some one may have been in there before you.
Salim
Salim
As far as the dome light goes have you tried a new bulb Yes and have you tried the switch Yes . you could put your voltage tester on the bulb connections and then try the switch to see of you have voltage No volts there . I can't imagine the dome light and the other items on the same circuit but I would start with what you did in the first place to see if it is the cause
I am willing to help, but you need to
a) list all electricals that are no longer working.
b) Point me to a place where I can look up the wiring diagram. [ I don't have electrical wiring service manual]
Salim
Salim
a) list all electricals that are no longer working. The ones I know are: - the courtesy llghts, remote unlocking, the display.
b) Point me to a place where I can look up the wiring diagram. [ I don't have electrical wiring service manual] Am I allowed to attach one on this forum please )
54.5 megabytes, will it post in one go please?
Salim
Salim
