Throttle body vacuum leak help
Old 12-03-18, 12:16 PM
Dukenukemx
Dukenukemx's Avatar
Default Throttle body vacuum leak help
Just did a smoke test on my uncle's 1999 RX300 and the leak comes from the throttle body where the spring is for the shaft. It keeps getting a P0171 lean code and it's annoying as hell. I tried looking for a new throttle body and I can't find any, and I don't wanna try my luck with a used one as this is a common problem from what I've been told. Is there anyway to change the seal in the throttle body shaft?
Old 12-04-18, 07:03 AM
ricco750
ricco750's Avatar
I found this after a quick search. https://www.discountpartsmonster.com...ttle-body-scat
Old 12-04-18, 11:52 AM
Dukenukemx
Dukenukemx's Avatar
No, it's leaking from the throttle plate shaft, where the spring is. I don't see anyone that sells it so I probably have to buy a used throttle body. I would need a rebuild kit to change the seals and stuff on the throttle body. I'm trying to see if I can get just the throttle body with the spring, since that's where the smoke came out of. The part # is22283-20130 which according to the dealer is going to cost $258. Jafromobile shows what seals I'm talking about, except not on a Lexus RX300.
Old 12-28-18, 02:41 PM
Dukenukemx
Dukenukemx's Avatar
Ok I fixed the problem and it was a couple of things. It was leaking from the throttle body pretty badly and I bought a junkyard one for $100. Not exactly the best of condition but it leaks far less than the original, so I'm happy with that. Also my Denso O2 sensor was fake it turns out as I ordered the same sensor for the bank 2 front of engine and the exact problem started happening, but by installing the original the problem went away. Spent $130 on RockAuto for a proper Denso and in the middle of returning the fakes, though the seller is upset that I left a bad review on Ebay. Just a warning to anyone thinking of buying a Denso off Ebay to save money. Don't, it'll cause the bank to run lean and cause a P0171. If you have a p0171 then get a smoke test and look at the throttle body. I made a video to help people out.
Old 12-28-18, 09:57 PM
maxSteel
maxSteel's Avatar
The picture of the sensor on the densoautoparts.com site looks like the one you got from rock auto
Old 01-01-19, 08:44 PM
Dukenukemx
Dukenukemx's Avatar
Yep and so far everything works fine. The fuel trims seem to move correctly for both bank 1 and bank 2 where as before bank 1 would be all over the place where bank 2 stayed more steady. Definitely fake as hell. I never heard of densoautoparts but I'll definitely book mark it for easy shopping. I paid $130 for mine so it seems I still got the best deal.
Old 09-25-19, 04:51 PM
Xavier56
Xavier56's Avatar
Hi I have 2000 RX300 - are you saying that you get the P0171 with the Bank 2 Senor being bad or changed too. I thought that Code is only for Bank 1
I got the P0171 and changed the Bank 1 Sensor in the rear with a Ebay Sensor. Have run car have St Trim +19,5% and Lt Trim 52.5%
If I hit accelerator St Trim goes to 0% ,Then goes back to 19% - have done smoke tests all over and do not find any leaks or any other issues to cause this code.
Will go and get a another sensor tomorrow - Bank 2 Trims run find. - any other Thoughts??
sagarx
12-03-20 03:50 PM
bighead222
SC- 1st Gen (1992-2000)
05-16-11 05:17 PM
bighead222
05-16-11 03:02 PM
Quick Reply: Throttle body vacuum leak help
