Knock sensor issue.
And I'm not sure if this would matter or not. But on the live data my mass air flow was reading 0.02 lbs at 1500rpm and intake air temp read 75 even though its 55 degrees
I usually use grams per second measurement. Which would be roughly one gram for every liter of the engine size. Which would typically be around 3 to 4 at idle. But if you convert grams per second to pounds per second it's usually around 2 hundredths so I would say that reading is correct. Also the engine room temperature is what's causing the variation from 55 to 75 degrees. I don't believe that's anything to worry about. You can try cleaning the thermistor inside the mass airflow sensor and see if they that cleans it up a bit. But that will not explain anything to do with the circuit issue with the knock sensor.
Didnt think so. I'm just at a loss on this thing. I'd hate to shell out the cash to replace the ECM and that not fix it. That's 600 bucks for a Reman at least that was what lexus in nashville quoted me.
don't forget immobilizer programming is in the ecm also. I would like to know if the pin fit is good from the connector to ecm
Lets summarize it.
Original code was a 330 (Bank 2)
New KS OEM
New KS harness OEM
325 (Bank 1) spits out after driving.
No pre-ignition/detonation ect... detected per OP.
325 code stays after swapping B1 and B2 pins to the ECU. (no change)
If you dont see any corrosion (green stuff) around the ecu KS pin for Bank1 and pin fit is tight, its very safe to say your next step is the ECU.
It just bugs me after your repair on the 330 code, this problem appeared.
Might be just coincidence but baffling to me.
New KS OEM
New KS harness OEM
Lets summarize it.
New KS OEM
New KS harness OEM
New KS OEM
New KS harness OEM
Baffling to say the least. I'm on my last straw with it. An instructor of mine is both a lexus master tech and was the lead electronics guy for the lexus he worked at and I asked him the same things about 45 minutes ago. He's baffled just as much as you guys are he really doesnt know where else to look besides replacing the entire harness
If he believes its the harness, you can actually run a single wire from that KS straight to the ECU.
Just make sure its a sheilded wire.
But, none of us here is a Lexus Master tech.
I still think its the ECU.
my 2c:
We are all going by hunches. Lexus Master tech (with the electronics as his major) has the distinct advantage of knowing what part fails.
But, nothing is based on measurements.
I would say just scope the signals and overlay over each other to see if the ECU is getting the right signal [lot easier as we know that one is good].
Salim
Salim
