Would Focal IC 165 TOY fit as replacement speaker?
Old 01-06-19, 02:06 AM
JohanH
JohanH's Avatar
Default Would Focal IC 165 TOY fit as replacement speaker?
I am looking for an upgrade for the stock speakers.
Has anyone tried or knows if the Focal IC 165 TOY or IS 165 TOY would fit in our cars?
https://www.focal.com/en/car-audio/c...otar/ic-165toy
They look similar enough but I would want to be sure.
Many thanks in advance
Cheers,
Johan
Old 01-06-19, 07:17 AM
sktn77a
sktn77a's Avatar
Looks like it should fit but the Crutchfield site says no.
Old 01-06-19, 08:53 AM
JohanH
JohanH's Avatar
Thanks. I found Crutchfield as well.
Here are the only measurements I have found until now: bit difficult to read but maybe someone can compare with the stock speaker.
Cheers again,
Johan
Old 01-08-19, 02:00 PM
sktn77a
sktn77a's Avatar
It's the plastic adapter (that's built into the speaker) that may be the problem - the door profile on the RX would have to match the door profile on whatever car is listed as compatible.
Old 01-09-19, 12:32 AM
JohanH
JohanH's Avatar
Thanks for your answer.
It's all Toyota; I would be very much surprised if it would be radically different as these cars have so many interchangeable parts.
Having said that I've decided to take a slightly different route using standard (Focal) speakers thus either needing 'Toyota' speakers adaptors or having to remove the Pioneer speakers from the existing adaptors.
Cheers,
Johan
Old 01-11-19, 02:25 PM
sktn77a
sktn77a's Avatar
Unfortunately, I don't think either approach will work. The plastic "adapter" is part of the speaker frame and cannot be disassembled. You'll likely have to get custom made adapters.
Old 01-12-19, 09:17 AM
JohanH
JohanH's Avatar
It seems these would fit the bill
http://metraonline.com/part/82-8148
Cheers,
Johan
Old 01-14-19, 06:05 PM
sktn77a
sktn77a's Avatar
Certainly appears like they would:
"Lexus RX front and rear locations 1999-2003"
Also surprized that all of those Toyota/Lexus vehicles have the same inner door profile!
Old 01-15-19, 04:43 PM
mike191
mike191's Avatar
those adapters above are just off alittle you would have to drill new holes. I would go with
https://www.installer.com/item/displ...php?it=82-8151 as i did
JohanH (01-16-19)
kambam3627
06-11-19 06:26 PM
FuMoFFuTT
SC- 1st Gen (1992-2000)
15
06-25-10 10:54 PM
haze
02-22-08 03:21 PM
OutlawTita
08-10-05 03:06 PM
Quick Reply: Would Focal IC 165 TOY fit as replacement speaker?
