Rx01 blower stopped working.
The title is misleading. or maybe not.
Blower by itself should be controlled by fan speed. If it does not respond to slow to max in steps then there is a blower problem. [check the fan control module].
If the speed is adjustable and the issue is with selection of vents which direct air then trace the mode servo thread.
If the problem is with temperature of the air and cabin temperature setting then check the air mix servo.
Salim
Salim
GStatus
01-07-16 10:44 AM
kh4nh
01-26-15 08:59 AM
