Need help on error code p0171 and p0174
I have a 2002 Lexus RX300 with 79,000 original miles on it and lately the check engine lights been on. Check with autozone and first I got error code p0141. I replaced O2 sensor on down stream, after the cat and that fixed the problem.
Now, I'm getting p0171 and p0174. I've read several forums about this issue, but if someone can guide me the the source that would be a help. Thanks.
Those codes are indicating a lean condition in both bank 1 and bank 2 of your engine. Thus your system is measuring less air intake than is actually going to the engine. This means you either have a bad MAF sensor that is incorrectly measuring the air intake, or there is some opening after the MAF sensor position that is allowing unmeasured air to enter the engine.
Look for any cracks or in the hose, or a problem where the hose connects to the throttle body. If nothing obvious is wrong there, I would change the MAF sensor, especially if it has never been changed before, or was changed to a non-Denso or non-OEM sensor. The part is a Denso 197-6020, and I had to change mine to fix a similar error.
Thanks a bunch Lexmus, will check first thing in the morning. I want to fix this and keep the car for a while since it still looks and drives like new. My mother gave it to me since she got tired of seeing lights go on like a Christmas tree. Every time she takes it to the dealer, it’s like $400 to $500 pop.
Its always been garaged so the paint looks new and since it’s got low mileage it drives like new. Mechanicaly it’s in excellent condition, it’s just the sensors going bad due to it just getting old. It’s 2002 by the way with 79,000 original miles from an old lady (my mom) I’ll post some pictures after I get this all fixed.
I've been driving this for about two weeks and no lights at all. Man, so happy now...the car looks great, car runs great, smoother engine idle, better gas mileage, faster rev and pick up. Thank you guys for the inputs and great forum. Over and out, until next time, hopefully not too soon.
Good news.
I recommend checking your fuel trims to see if they are high even though you no longer are getting a CEL. The P0171 and P0174 codes are triggered when the trims are over 25%. You could still have abnormal fuel trims and not exceed 25%. When I replaced the MAF, cleaning didn't work, and the bank 1 long term trim was around 25% and bank2 long term trim was around 20%. Thus only the P0171 code was triggered even though both banks were abnormal.
I can monitor the trims when necessary using a cheap bluetooth OBD2 reader from Amazon and the Torque app for android.
Good news.
The 25% number is my understanding when I was leaning how to fix my P0171 code and was consistent with the fuel trim data I saw on my car prior to the MAF change.
Ideally the long term trims are near zero and the short term does fluctuate but around zero. But I think they should be under 10% in total. Fuel trims that consistently greatly deviate from zero means you have an issue with a sensor or the fuel system. You can't adjust the trims directly, they are the result of all the data from the sensors being sent to the ECU.
My thought is, you improved the MAF with the cleaning, the code went away, but it might still be wounded. And running lean is not good for the engine. This would be a good time to get some experience looking at the trims by getting the inexpensive equipment to do so, and understand how your car is truly performing given the codes you previously had.
