2002 RX300 valve cover replacement
Does Lexus replace valve cover gaskets during 90K and 180K maintenance which includes timing belt replacement (for a 2002 RX300)?
Does Lexus replace valve cover gaskets during 90K/180K maintenance after installing new timing belt (2002 RX300)?
They will if you ask them to, extra cost of course.
I don't think it's listed in the recommended maintenance schedule, but I don't have it in front of me to be sure. I doubt they'd recommend replacing them if no leakage is occurring.
It is not a scheduled service item and should be replaced if it is leaking .. which it typically does after 8-10 yrs. The heat cycles just make the gasket shrink and then leak.
Salim
Salim
Piyush
17
12-06-15 07:30 AM
