i'm at my wits end with this thing
#31
Hi had the almost the same nightmare your having - changing all the parts you did.
I found out you need to have a Code Reader that can read engine live data like STFT and LTFT on both banks
You can see which one has a issue or both.
Then like others said I replace the O2 or Air Ratio sensors in the Pipes -
I had one Fake one that cause issues and a Second one that was New was Bad.
Just because it is brand new does not Guarantee it is good.
Good Luck
Good Luck
#32
Hi dakiwi13, Saying it one more time and I leave it alone I promise. lol
You need a scanner with live data to get thru this or you are wasting your time and money.
PS- Buy your own and keep it with you at all times- best money $ you ever spent.
Nad1370 (01-27-20)
#33
If it is indeed a failed(failing) AF sensor(s), please get an OEM/Denso genuine part.
There are a lot of FAKE Denso’s out there.
BTW, there are 2 AF sensors.
One on each bank located at the exhaust manifold.
And 1 O2 sensor located before the main CAT (underneath the driver seat under carraige)
#34
If you have an Android phone or tablet go to Google Play Store and buy Torque Pro, then go to Amazon and buy a Bluetooth OBDII adapter. Learn how to use the software. The total cost should be under $20.
#35
I use this setup on my SC400. The SC throws a fault Throttle Position Sensor about every 10,000 miles or so; I have to coast to the side of the road (5 mph limit) to reset the code, then I'm good for a long time. Had the TPS replaced, but it still comes back sporadically. With the wireless OBDII always installed, I start Torque Pro and do the reset, then good to go.
I suspect the caps in the ECU are failing, but don't know who can repair the ECU properly.
#36
i have it done already, it's on my phone, i just gotta get it onto this page to show the numbers
#37
#38
Bank1 sensor 1 and Bank2 sensor 1 are air-fuel ratio sensors and not O2 sensor. If you replaced them with O2 sensors then that is your problem.
https://shop.advanceautoparts.com/fi...l-ratio-sensor
#39
This happened to me too!
I bought a fake Denso Air/Fuel sensor on ebay in a OEM Toyota box.
Car ran like crap and thew Check Engine Light immediately- bought an genuine Denso at autoparts store and problem fixed.
#40
Yes Like I said Earlier exact same with me - I got Two Fakes from Two Different Sellers -
Note ; they both refunded money once I said were fakes - no questions asked.
Once Replaced with real ones from Local Auto Parts Store -
Started Car with Code Reader reading live data from STFT and LTFT - All Fixed
I knew right away from Data Seen
Margate330 (01-28-20)
OilMemes
RX - 1st Gen (1999-2003)
15
04-15-18 09:36 AM
