Rx300 Charcoal Fuel Vapor Purge Canister Ports ??
Old 01-26-20 | 03:46 PM
Xavier56's Avatar
Xavier56
Default Rx300 Charcoal Fuel Vapor Purge Canister Ports ??
Hello All,
Can anyone identify these four ports on where they come from to connect to the Canister ?
Want to know which one is for the Gas Tank
Thank you
Old 01-26-20 | 04:32 PM
Nad1370's Avatar
Nad1370
If my memory serves me right:
1. Air inlet
2. Purge
3. Vent
4. Evap — fuel tank
Old 01-26-20 | 04:42 PM
Xavier56's Avatar
Xavier56
Thanks for the information
Questions
1. Air inlet - Air from where? There is a hose on this one that goes up someplace ?
There is a bigger hose in picture far left next to the 1 has a Hose open to the air already
2. Purge
3. Vent
4. Evap — fuel tank - is this from the tank check valve?
Having trouble getting gas in tank - want to put slight vacuum on it ti see if can open or slight pressure on gas tank to see if air comes out hose
Thanks
Old 01-26-20 | 05:37 PM
Nad1370's Avatar
Nad1370
Questions
2. Purge
3. Vent
Thanks
Really picking my brain here. lol
Air inlet is coming fron the CCV up by the airbox
Purge is also up from the engine are where the GREEN access port for the evap system is.
Vent is also coming from the tank where it tee's in with the ORVR valve.
ORVR operation is,
during refueling, low pressure above the diaphragm in the onboard recovery valve lifts allowing fuel vapors into the charcoal canister. At the same time, the air drain valve opens and the charcoal absorbs the fuel vapors. <--- could be your issue as well (aside from a plugged up canister) if its stuck and not allowing fuel vapor to the Canister.
I would disconnect this corrugated Vent hose and see if you can refuel normally.
Old 01-26-20 | 05:44 PM
Xavier56's Avatar
Xavier56
Worth a shot - I filled up today so be a while till need gas - when gets down some will try
I have a low pressure smoke machine too so maybe try that too from the gas cap with that vent hose off
Thanks
dejacky
Performance & Maintenance
36
04-27-17 11:00 AM
JAB
03-21-16 03:47 PM
primo
12
04-07-12 11:50 PM
mikemareen
06-05-08 09:18 PM
