No power to the fuel pump
Old 02-14-20, 05:56 PM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Check voltage at [E] and move sequentially down to the fuel pump. There are two relays in the path. If there is a break then check that the primary side of the relay coil is being energized.
Salim
Old 03-20-24, 07:53 PM
Geonico
Geonico's Avatar
Did this get a resolution? How was it solved?
Old 03-21-24, 11:54 AM
salimshah
salimshah's Avatar
The problem is not generic and it needs to be diagnosed with the help of the attached circuit diagram .. thanks to @Margaret
Best is to trace back from the pump for 12v. Keep in mind it is not constant [modulated on/off ... in case of an accident the pump is cutoff]. Bringing the key closer or opening the door to enter is a signal for the ECU to turn on the pump to prime up the pump.
Share with us what you find out and we can suggest what else to test/check.
Salim
Trucho
Performance & Maintenance
01-01-21 01:29 PM
kaduku
06-17-15 11:45 AM
Trucho
06-11-14 04:54 PM
xsc2003
12-12-08 08:16 AM
Quick Reply: No power to the fuel pump
