Found after market android radios air con etc for rx300
#46
#47
For the persons who bought these a year or two ago, how are they holding up? I am thinking of getting one as my screen is damaged, it has several lines running through it and is quite dim.
I am thinking of getting the smaller screen that keeps the original control *****.
#48
Cheers,
Johan
mhay (06-21-22)
#49
But you're losing climate control and various other readouts, which for me would be too much of an inconvenience.
I'm seriously considering the previous one with the 10.1" screen.
I contacted the seller and they assured me that it would be plug and play for my car.
Just hoping I won't be a beta tester
Edit: ordered one, will report back
#50
#53
My radio died in my Harrier and I ended up buying one of these late last year (10.1" screen). Due to lack of time I didn't get around to installing it until about May this year. I had various issue that ended up being due to a ground disapperaing and also due to the factory JBL amplifier (located under the dash on the driver's side, not around the back like in the RX300). I ended up bypassing the amplifier and running the speaker outputs from the radio directly to the speakers. It sounds OK, but I am no audiophile.
Overall, it is a nice interior upgrade and I am pleased with it.I still have the GPS antenna, reverse cam, hands free mic etc. to install. Not sure I will be bothered with all of that as I never had any of it from factory. The reverse cam will be the most useful to me, but also the most difficult to install by far. To do it properly will need a lot of removal of trim pieces that will likely have brittle clips from nearly 30 years of age. I might be more tempted if I find a good how to. will search on here.
ddoxey (05-27-24)
#55
Wife wanted a new vehicle since her RX300 is already 25 yrs old . The RX300 works excellent and is only ~144k+ miles. Well, I bought her the following instead:
She can't be happier. This is an excellent upgrade. It just extended the life of the vehicle by another 5 yrs at least.
ddoxey (05-27-24)
#56
Salim
#57
It was self-installed. It's plug and play. All wire harness is provided. There is no wire harness to modify or cut. Only 3 wires from the backup camera needs to be stripped off to tap to the reverse wire in one of the harness; and positive and negative wires of tail light. I purchased it from here:
https://www.aliexpress.com/i/3256803894628899.html
You can find one cheaper here with minor differences. For example, Android 12 vs 13 not that it makes any difference. They were out of stock when I was ready with the purchase:
https://www.aliexpress.us/item/2255800983721387.html
I got the 8GB+128GB with front camera DVR, rear backup camera, and paid extra for TPMS and USB hub. There is no installation instruction provided but it is easy to figure out. There was only 1 instance where I have to message customer support because the climate control didn't work. They created a step-by-step procedure in setting up the climate control app complete with photos just for me. It turns out I didn't install the 2nd CANBUS provided that says "RX330". Customer support is excellent. I got reply in minutes.
Overall. it was easy install. Just plug whatever plug matches.
#58
#59
So far I have not experienced any operational issue. BT, WiFi, GPS, wireless Carplay, DVR, radio, DSP, TPMS, and rear backup camera works. The Android eco system is now quite large. There are various apps that can be sideloaded - new theme, better UI, more features, etc. The only thing I am missing is the mpg. I can see km/l on the provided app but have not found a way to convert that to mpg. I'm sure there are other apps that can do that but I have not delved to that yet.
I only got ~200 miles on it. I cannot speak of reliability yet.
maxSteel (01-29-24)
#60
I am currently working on installing one of these.
Android for RX300 install in progress
The problem I'm trying to overcome; the climate control controls. The mode control works a little bit, but not really. And there seems to be no ability to toggle the recirculate function. I don't see any way to toggle the AC on/off either.
Android AC controls
The fan speed selectors work, and the temp up/down controls work.
I don't know what the up/down control on the left edge controls. It doesn't seem to do anything.
The circle / triangle on the extreme right appears to affect the mode selection -- but not reliably, or completely.
I contacted the eBay vendor. His first remark was that I should find someone with more experience to install it. Nice. But he did also provide some additional information which didn't come included with the device. While informative, it confirmed that I was indeed plugging it in correctly and that the CAN settings were correct, for Toyota RX300 "High"
Anyhow, if anyone with more experience has any helpful suggestions, I will be very grateful.
Android AC controls
