Hesitation
Originally Posted by additude
Typically after slowing down to make a 90 degree rolling turn onto another street my RX will feel like it's hesitating just a bit before it takes the gas and starts to accellerate.
It's like when I'm doing under 5 mph and I slowly push on the gas pedel, I get the sensation I am pushing the pedel but I'm still coasting, then the RX takes the gas, does a slight lurch to speed up and then runs smoothly.
It's like moving your mouse and the pointer doesn't move, then all of a sudden the pointer jumps to where it should be and works fine.
It's not all the time. Just some times.
Any ideas?
Thanks.
Any ideas?
Thanks.
I am convinced that the condiction of the transmission fluid does affect shifting smoothness. Is the fluid a cherry red in color and at correct levels, cold and hot? Sometimes, a couple of drain and fills might be needed in a thousand miles to get the fluid color and clairity. (indicating impurities). I noted a marked difference in shifting after I changed mine.
It may also be time to reset the ECT by removing the negitive battery terminal for ten minutes or so. This causes the tranny to "relearn" your driving habits.
