No power please help!
Had idle issues so replaced IAC valve. Car started, turned off and would not restart. Replaced alt fuse and all related fuses. Took battery in for test and tests good. Absolutely no power anywhere. Not even lights. Please offer advice
If the battery is installed with swapped terminals the main fuses can pop. In the engine compartment there is a long fuse box next to the battery. The main fuse is bolted in.
Salim
Salim
