Single click, then lights go out when trying to start
I didn't drive my 2002 RX300 (200k miles) for ~2 weeks and the battery is several years old, so it wouldn't start up. I tried using my (cheap/low amperage) portable jump starter pack, and got the starter to turn a few times (3 or 4 bouts of 3-4 seconds), but it didn't have enough juice to start up. I ended up buying a new battery (with 750 CCA) and put it in.
Now, when I try to start it, the lights all come on on the dash, but when I crank the key, I hear a single click. Then all the lights shut off, and all electronics become unresponsive (turning the key does nothing). The only way to reset it is to disconnect the battery for a few seconds, reconnect, and try again. But the same thing happens — single click when turning the key, then lights out.
Do you think my starter motor might be burned out? Could it be a bad connection to the battery? How do I fix this situation? Thanks!
