Security light flashes
My cars security light is flashing and causing my car not to start but it will turn over how do I reset it so my car will crank
Salim
did you fix it same issues I’ve swapped at ecu and key ignition no luck still flash used my ecu and key ignition in my other car starts up fine no security light any help
If you have replaced your ecu with a used one it will need to be "flashed". This will reset the immobilizer. I can help with flashing.
We really need to understand what is going on first.
Salim
JDMCelsior
02-07-08 04:35 AM
