Door actuator advice needed
Hi all - I've read here and watched a lot of videos about replacing the door actuators in the first gen RXs. So I was able to get most steps down quickly, until I hit a challenge that is not shown or discussed. So I'm asking those of you here who have done this.
I have freed the actuator and cover from the door connection points, it'll move freely up or down with everything disconnected. But I cannot pull it out. This is the driver's side front door. There is some sort of bar running at a slight diagonal which traps the actuator against the door skin? I believe I *could* unbolt the bar at least at the bottom of the door. What should I do and what should I be mindful of, before I try this?
Thank you
Thank you
Thank you
Thank you
MtnFrost (06-29-21)
Thanks, I finished this door and all is working great. I did, however, have trouble once everything was installed with the window not wanting to go down beyond a quarter. Careful double-checking revealed no issue except a bend in the top half of that window runner, where the rubber has no support. I massaged it a bit by unbolting the runner again and sliding the lower metal support on it up and down a bit. Then all was well.
And the remote immediately worked with the door, too. No messing around resetting codes or anything. Now, only 3 more to go. At least I now have the driver and hatch locks done. Those locking door connectors were a challenge for a big guy with meaty hands. But going slow, being patient and not forcing anything got me there.
ricco750 (06-29-21)
Good to hear that things went well. Just one careful and do not be in a hurry to attach the panel/cover. Test the lock for couple of days.
Salim
Salim
Lubeboy
SC- 1st Gen (1992-2000)
05-30-17 12:52 AM
tonyzebra
15
08-22-12 04:40 PM
