Rusting out OEM Cargo Rack
Old 07-07-22, 10:03 AM
Jrperdue20
3rd Gear
Jrperdue20's Avatar
Default OEM Lexus Cargo Rack assembly Pieces
I bought my Lexus in January and it came with the OEM cargo racks Lexus sells. 1 of the 2 racks is perfectly fine but the rear one is rusting/bent and extremely hard to move. If I removed the screw and attachment Peice it screws into will I be to buy just a replacement for the attachment the screws fasten into? I see that Lexus currently sells pt27848992hw roof rack hardware kit. Would this be a viable replacement for the current hardware?
Old 07-07-22, 10:15 AM
Jrperdue20
3rd Gear
Jrperdue20's Avatar
Default Rusting out OEM Cargo Rack
Bought my RX in January and the rear rack attachment peices are rusting out/bent and will no longer attach when I remove the rack by unscrewing the attachment peices. That said if I buy the roof rack hardware kit: PT27848992HW
That Lexus sells will it be a viable replacement for the current OEM peices in the vehicle? Would like to confirm it’s the correct peices before purchasing a replacement because Lexus dosnt have any photos to confirm it’s the correct part. Thank you
Old 07-07-22, 10:27 AM
Received 3,061 Likes on 2,573 Posts
This kit is only $12 why not just order it. Says fits your RX.
Old 07-07-22, 10:31 AM
Jrperdue20
3rd Gear
Jrperdue20's Avatar
Default Just checking
Just checking to make sure before I make a purchase. I know it says It fits my vehicle but dosnt hurt to make sure it comes with the correct peices.
Old 07-07-22, 10:50 AM
I can't find any info on that kit other than it ways fits RX. Hopefully someone else knows.
Jrperdue20 (07-07-22)
Old 07-07-22, 07:25 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,106 Likes on 995 Posts
There are rails and slats. The rails are afixed to the body and slats can be moved back and forth.
Your best bet would be salvage yard for the slats. You can check with Lexus to see if they have new ones.
You can jury rig, but be careful about length and material of the bolts.
Salim
Also dig in the really old posts about wind noise due to these slats. Lexus finally had a recommended position.
Jrperdue20
07-07-22 07:25 PM
Deadsea
UX Models (2019-present)
10-25-20 01:11 AM
blkstealthpaid4
09-29-20 11:44 AM
mochiball
08-29-06 02:07 AM
Quick Reply: Rusting out OEM Cargo Rack
