RX300 Brake Light Short
Old 09-12-22 | 01:46 PM
nanomatrix's Avatar
nanomatrix
10th Gear
Default RX300 Brake Light Short
I've taken care of this 2000 RX300 for over 20 years. But I can't figure this one out.
I've checked all the brake light bulbs. They're all ok.
But every time I put a new fuse in the socket, it blows.
I haven't checked the brake light switch because all of the problems I've seen with the BLS are open circuit problems.
Any suggestions on what could cause a Short?
Old 09-12-22 | 02:43 PM
ryanSC300lover's Avatar
ryanSC300lover
on mine i have a “tail lihht out” bulb in instrument cluster 2 years
all rear lights work
even replaced them
that light is still on
Old 09-12-22 | 02:51 PM
ricco750's Avatar
ricco750
even replaced them
Even the side marker lights and the high mount stop light ?
Old 09-12-22 | 03:04 PM
nanomatrix's Avatar
nanomatrix
10th Gear
Well, with the fuse blown the brake lights don't work and I can't legally drive the car.
One other issue.
I have to push the shift interlock button to get the car out of park.
Old 09-12-22 | 03:16 PM
maxSteel's Avatar
maxSteel
One other issue.
Maybe you should check the brake light switch after all
Old 09-12-22 | 03:58 PM
nanomatrix's Avatar
nanomatrix
10th Gear
I just removed the brake light switch. That power outlet was the hard part.
Anyway, nice clean silver solder joints no discoloration.
and I'm still blowing fuses.
Old 09-12-22 | 04:25 PM
maxSteel's Avatar
maxSteel
Looking at the wiring diagram the 20A stop light fuse is connected to pin 2 on the stop light switch connector via a green-black wire.
Assuming the wiring chart isn't "simplified", if the fuse is blowing with the stop light switch connector disconnected it's got to be the connector or the wire between there and the fuse.
Old 09-12-22 | 09:45 PM
salimshah's Avatar
salimshah
Discoloration [green stuff] is typically a high resistance point. You have a short.
Salim
Old 09-13-22 | 06:26 PM
ryanSC300lover
yup all ok
weird isnt it?
Miketheg
03-21-22 10:40 AM
DDLexus
23
03-11-15 12:03 AM
uplusd
04-05-07 11:06 PM
nysupraman
06-01-05 01:37 PM
