2009 rx350 shifter console trim
drives cars
This should be in the RX sub-forum. Moving.
If I can find a Pic of the Woodgrain trim, I'll post it.
I’m pretty new to CL so hopefully I’m responding to your question correctly. I just got a 2008 RX350 last week and the shifter wood trim was curling up so I removed it (never had done it before as I’m not handy) and put vinyl wrapping on it. You can use anything flat and hard plastic to pry it off. I used a mtn bike tire lever and started from the bottom. It only took about 30 seconds.
See the top part of this trim? It’s curling up.
You can see how badly it’s separated from the plastic frame
How it looks with the vinyl wrap
