Need urgent advice 2009 rx350 51,000 miles oil leak
10th Gear
Please help me. I have a 2009 RX350 with 51,000 miles. I went to the dealer for an oil change and the mechanic at the dealer shop said everything is in very good condition EXCEPT I have an "active" oil leak in the REAR CRANK SEAL (Crankshaft Rear Main). He said that although the oil is not leaking on the floor, the oil leak is an "active" leak and he pointed out where the oil is leaking and he also pointed out that the lower shield has oil on it. I do not see any oil on my garage floor, but I believe the Lexus dealer because he pointed it out to me. I also had it inspected by an independent mechanic who said the same thing as the Lexus dealer mechanic: there is an 'ACTIVE OIL LEAK," in the rear crank seal. The Lexus dealer quoted me an estimated price of $3,033 to do the repair. He said that he will need to lower the transmission to replace the seal and then put everything back in. The independent mechanic said it's a big job to do. My relatives who are car "geeks," told me I should not get the oil leak repaired since the car is old. They told me just check the oil levels periodically and to just add oil to the car when it gets low. The service advisor at Lexus told me I should get it repaired ASAP as the engine could cease. As I mentioned, it's a 2009 RX350 with 51,000 miles and besides this oil leak, everything else is in very good condition. What do you think I should do? Please help me make a decision. I appreciate your help!!
Vincenze (04-12-23)
Just keep it topped off until it drips on the driveway, then if your spouse lets you, put some carboard there (duct tape to hold it in place) and carry on. If yoy can DIY it, then fix it if it drives you nuts, but if a dealer says its leaking, and you never noticed, move on...
Abrar (04-13-23)
10th Gear
Thanks - that's a very interesting video. Now, I understand why it's so expensive to fix the RMS. I wish I lived closer to this guy. I would bring my Lexus to him, but I live in NJ. I wonder how I would be able to get in contact with this guy? He seems really knowledgeable.
10th Gear
Thanks for your response. But, with everything else you recommended, I could be up to $5,000-$6,000 in repairs. I am struggling to figure out if it's really worth it to fix the REAR MAIN SEAL which the dealer gave me an estimated price of $3,032, and now, you made me realize that I might have other major repairs to take care of as well as the RMS. It's a 2009 RX350 so, it's 14 years old. I am the original owner, but, I am worried that this vehicle will turn into a money pit. What do you think I should do? Should I just keep an eye on the oil levels and pray it doesn't get worse or should I bite the bullet and take it in for the repairs?
10th Gear
Yes, I have photos from the dealer. I have attached two photos to this reply. Please check the attached photos and please let me know what you think. The first photo is where it's leaking from (He said that it's leaking from the rear crank seal. The second photo shows the oil on the lower shield). I am really struggling with this decision. It's a lot of money to replace the RMS and my car is a 2009 RX350 so, 14 years old. Should I do the repair or should I just monitor the oil level? The other idea I had was asking the dealer if they could use more viscous oil or have them put in Auto-Rx both of which I see mentioned on this Lexus forum.
photos are low resolution, can you send ones with good resolution ? its looks like a seepage at best ! not a leak, monitor oil levels every 1000 miles/ km , check levels, some times its better to top off then to spend 6K $
Chaiya1 (04-13-23)
the video mentions the timing cover leak, 2grfe is known for this. use a break cleaner and clean the oil leak, top off the oil, drive again and check oil levels, and check for leakage. some times its way cheaper to top off with some oil than to do a engine drop and repair.
Chaiya1 (04-13-23)
10th Gear
10th Gear
Just pretend you had the oil changed, AND, nothing was mentioned of this leak by the shop.
Life would of gone on without any issues, right?
Until it starts making a mess on your garage floor (it may never), just drive and enjoy your Lexus and save your money for repairs that actually affect the driveability of the vehicle.
Brakes, exhaust, tires, shocks are all things to worry about rather than this issue.
As far as the service adviser saying the engine could seize, it’s their job to scare potential victims into spending money, no reputable mechanic would tell you such malarkey.
10th Gear
