Nd11 ac oil how and where (merged ac issue threads)
I get this strange subtle but annoying air con humming noise especially when idle to accelerate, or low speed creeping...
any idea what and how to fix it?
Maybe because i have added freon, ac was empty completely, or added cleaning foam on evaporator?
Should I add oil when topping up?
r134a leaked out.
I want to add some more r134a.
should I add ND11 oil too, or all the oil stays in the compressor, and there is no need for it?
Why is ND11 SOOO expensive?
how much oil to add?
where to?
How do I find out how much oil is in the system?
where to?
Vacuum and collapse
If i vacuum AC then the low pressure valve would collapse and intake air from outside till it reaches 1 bar right?
I don't understand how to add r134a and a sealant.
If I do without vacuum the the pressure is already there and i cannot add
I just don't understand how to introduce gas into ac system
Is vacuum pump only used to suck out air and moisture?
Thus instead of air there is a r134a gas
Ac low pressure and high pressure psi?
What is the max good AC low pressure and high pressure psi at 30 degrees Celsius?
should i rev the engines or on idle enough?
rx400h 2008
I Should not care about grams and cans, look at high and low pressures psi right?
rx400h 2008
>>>>Best to take it to a shop & have it repaired correctly........
loliwin55
ES - 5th Gen (2007-2012)
08-16-22 11:22 PM
