The Worst Transmission Mount I Have Seen
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/8bd0afc6_f8ac_4de4_a8e2_9e653fe13850_076a41bcf4d22e63c4573b36eec2cc025e8ddc2c.jpeg)
I thought mine was bad until I saw this:
Friend’s RX400h with 390k km
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/74845873_6996_436e_ab7b_4d15229030d4_88329de91767ca1984a79b80f6f1ba359e9c4dd4.jpeg)
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/27e42622_3bb5_4264_b683_08765d4ba566_4517ab3b950c80a6a16e705a0438d912c21339ca.jpeg)
HOLY SMOKES! Trans is a little smoother! I bet you’d be able to tell more without a CVT
Like my car, the rest of the mounts were fine. Have you guys had similar experiences with your 2nd gen RXs? Let me know!
AlexMan (12-30-23)
Looks the your weather really did a number on that mount, matt.........
MattRX (12-17-23)
Definitely! It was totally rotten, the boot was ripped which didn’t help either
Mine weren't that bad.
But I had to cut the engine mount off to do the control arms.
Waiting on that mount to come in right now.
Good times.
Good times.
Looks like a fine example of some delayed maintenance. Haha
Yeah, that mount is spent! Lol
![Golfer](https://www.clublexus.com/forums/images/smilies/Golfer.gif)
Chapp: Mine seized into the mount too! Thankfully I was about to get it off after removing the bracket off the engine and some heat and hammer strikes!
Margate330: Indeed! This poor 400h was mostly original but we're finally tearing into it and removing all the "cancer"!
Chapp (12-20-23)
MattRX (12-19-23)
For sure! So far we replaced all four struts with Sachs, I also made all the interior and exterior lights LED like my car so much of the same thing. I am going to add a heated steering wheel to it one day like me, and will definitely document it again and make another DIY.
I couldn't get to the bottom bracket bolt as it was seized in the bracket.
Chapp: Oh, I see!
Hugo: I got it used from a 2011 Lexus ES350. The V6 and i4 cars get different numbers (V6 prob stiffer). You have to grind a top locating tap off for it to fit
Matt: Yeah, for real I think the mount would've still been good otherwise.
Oh well. I went with a oem from toyota dealer. Got it for 160 and some change. Not too bad I guess.
I really had to fight and off and on to get the mount and bracket back on. It was a major PIA.
Also, I blew out the power steering reservoir and must of ordered a made in USA /Canada one.
Mine is made in Japan. I just got a longer hose and made it work.
The job, while straight forward ended up being a major pain. I guess i"m glad the power steering res failed on a fix rather than the road.
MattRX (12-22-23)
2jzgttegs
02-18-13 06:36 AM
