Parts list please for front lower control & Sway bar links
@leeper, Greed lives off suckers. The $203 shop rate and the 8 to 12 hours of shop time are weapons of Greed to numb the Sheep
please share specific dealer or aftermaret LCA's and sway bar links. Did you use excellent guide by @alchemist ? Kindly share any video showing how to replace lca's and sway bar links.
@tomr51, please share specific dealer or aftermaret dog bone, mounts, and LCA's and share any video showing how to support engine and replace lca's.
Sway bar bushing replacement - no video needed as it is extremely straight-forward youu will see them each has two bolts only takes a few minutes to change out though access to the bolts is limited
While there be sure to check out your ball joints, and sway bar links, both are quite cheap and easy to replace probably do it preventatively if good
@Leeper , many thanks. The video says to pull the shock out in order to line up lower control arm (lca) bolt. Did you have to that too? The guide by alchemist did not need to pull the shock and purchased the lca bearings and had them pressed in. Curious, why did you choose to replace the entire lower control arm when you could have just pressed in new bearings and ball joints ?
Suggestion - while there check:
Brake pads
Lube caliper pins
Check your sway bar links
Check your ball joints (mnew ones may come with your LCA's
Check steering rods ends
Clean lugs and wire brush your hubs dirt/rust
Rotate tires?
AustinSBP
08-15-23 02:05 PM
