Manual key does not unlock (nor lock)
5th Gear
Hello, I just discovered that I can not unlock (nor lock) with my manual key, my 2004 RX330. Lock/unlock with the fob buttons works as advertised. When I attempt to lock or unlock manually the key inserts without issue and rotation is equal in tension and equal in either direction, approximately 12 o'clock +/- 10 . There is no audible or tactile sense indicating the mechanism is locking or unlocking. I experience the same behavior with all four keys: 2 master (black), 1 sub (gray), 1 flat key. AFAIK, these are the original keys and I am the 2nd owner. Has anyone else experienced this? Is this an issue for the dealership?
Physical connection from key fob to lock is broken or detached. To diagnose you need to remove door panel.
PS: You need plan B in case of sudden 12v battery death - Dead battery, physical key not working, how to get intro get into car ? - Page 2 - ClubLexus - Lexus Forum Discussion
5th Gear
1. No physical key manually unlocks/locks the drivers door.
2. Only the two master keys turn over the ignition.
Seems to me this is an issue for the dealer. What do you think? Do you know if there non-dealer repair options for these issues?
The dealer can handle this, but it will be the most expensive option. Many locksmiths have the electronics to program new fobs if needed and can advise you if they can cut keys or if you need new lock cylinders. I wouldn't be too concerned about a new valet key, but you may be.
Thanks for the response. The plot thickens: I cannot start the car with either the gray nor the flat key - they do not rotate after insertion. It would appear I have two separate issues.
There are two independent things going one:
Key in ignition:
#1 - does your master and subsequent keys fit your ignition key hole and turn properly (was the key physically cut right)? if not you'll need to get one properly cut, keys can wear out over time or may have not been cut right to begin with
#2 - when a key is inserted into the ignition does the security light stop flashing (does your car recognize the microchip in the key fob)? If YES then it should start the car, if not then your car needs reprogramming to accept the key (done with Techstream or the dealership and be prepared to pay a LOT for something that should take them upwards of 3-5 mins to do)
Remote to open doors:
Do the buttons on your key fob operate the door locks? If not that is easy to reprogram yourself but first I'd suggest unless you know that the battery is new to change the battery... always read the date code on battery packets to ensure they are new as lots of realy old batteries are being sold out there and are dead upon arrival
There are ample YouTune videos showing how to use Techstream to program keys to your car as well as many showing how to program your car to accept a new key fob to operate doors
I'd remove a exterior door handle and check it out!
It may have been the car was stolen or the physical keys lost, and the door handle exterior locks were Disabled!
It's just an Idea!
DaveGS4 (02-08-24)
Jerry0249
01-23-19 08:33 AM
GrrrRx330
04-01-11 02:29 PM
