rear tailgate compatibility
I have a 2005 Japan built RX 330. The tailgate is damaged so I decided to change it out. I bought a rear tailgate off of a Canadian built 2005 RX 330. I installed the Canadian built tailgate and it bolted right up. The problem is that the tailgate will not close and latch. Any idea why?
Back door lock has a different pn. for Canadian and Japan-built cars. Maybe try swapping the latches between the trunks.
Update: There is full compatibility, everything is the same. No need to switch latches or anything else. I found out that the vehicle was previously in a rear-end crash and the body was pushed in so that is why the liftgate was not closing properly.
The following 3 users liked this post by Geonico:
