Uh-oh cr4p i think i broke it, CV Axle replacement question
Is this axle seal removable (front drivers side) 2006 RX 330 2wd
I am trying to get it out and it's just coming off in chunks. Then i noticed metal shining through and I'm wondering if this is permanently pressed in or something?
What's the replacement part? I have a purchased ATP RO80 OEM / Interchange Numbers: 9031150029
is that correct?
Thank you
is that correct?
Thank you
SJM (06-03-24)
Don't panic, all seals are replaceable, just try to get it out without scratching the transaxle, if you do, add a smear (very small) of RTV to it when putting in the new seal. Tip, if new seal has a spring, put some grease(or assembly lube) on it before tapping it in so it doesn't inadvertently pop off...
whew
Thank you mesquite and mattrx.
I was braver and used a crowbar to leverage it out.
:: boing :: it popped right out and spit the spring comically.
finished up the job and came back to say thanks, she's back on the road.
The following 3 users liked this post by ZN361:
If you haven't finished this, are you using a seal puller?
They work wonders.
They work wonders.
