Front Washer Fluid Pump
Recently discovered my *front* washer fluid pump has stopped working and I’m going to replace it myself. Has anyone ever made this fix before and have any tips? Or at the very least know where it’s located under the hood? Any help is greatly appreciated thank you!
I have a 2008 Lexus RX350
Last edited by BigMoneyDek; 06-06-24 at 02:35 PM. Reason: Forgot to include make and model
You have to take the front bumper off, it's on the passenger side. I would probably order a new grommet and I would get an OEM motor if possible.
Some pics in this thread
https://www.toyotanation.com/threads...1727980/page-2
I recently did the job. Bought a new pump from rockauto, on passenger side, unpinded and unscrewed some of the wheel cover to acess the washer reservoir, the pump is right there. I was able to take it off with some wiggle. The space is tight but doable.
Also prepare a container for the fluid to drain when the pump is off the reservoir.
