09 rx350 did hg, one plug not found
I had to drop the cradle and do headgaskets. everything went relatively fine. got pretty much everything back in place but by the a/c compressor there's an open 2 pin socket. the bracket in the picture bolts to a little 10mm bolt on the side of the a/c compressor but I cannot find anything to plug this 2 pin wire into.
https://imgur.com/a/PoAzXGQ
I really don't want to start it up with it unplugged but if I can't find it next time I work on it I might have to
edit, pulled the efans back out, shined a light and saw a small plug on the side of the compressor, has a c-clip holding it in
Maybe the AC compressor clutch or AC pressure?
Good Luck, I'm sure you'll figure it out.
3 possibilities, my guess is crank position sensor (hidden behind A/C?), and better plug it in before starting...
1) a/c compressor, no harm if left unplugged
2) alternator, again, won't run long but won't hurt anything
3) IIRC there is a crank position sensor or oil pressure sensor in the area lower down
Look at 2:30 mark in this video: https://www.youtube.com/watch?v=A0iVEHojWNI>
blkstealthpaid4
07-25-15 04:55 AM
dcdyd
04-11-13 08:58 PM
