RSES question..
Old 01-21-04, 08:40 AM
Fikse
Fikse's Avatar
Default RSES question..
Is there any way to have he RSES automatically display the DVD video source when starting up the car and dropping down the screen? right now when the screen is dropped down, you have to manually select the source.... not easy to do from the front seat when you want to play it for the small kids....
OR, is there any way to select the DVD source on the rear screen from the front of the car....
Old 01-24-04, 01:08 AM
ColeRX
ColeRX's Avatar
I use the remote control. Hit the "DVD" button for source which turns on the screen, then hit the "Cursor" button twice to clear the "Hints..." msg and the follow on menu buttons screen. There may be an easier way but the three button pushes works for me. Hope this helps!
Cole
Old 01-24-04, 08:48 PM
SprocketS
SprocketS's Avatar
Default We can't be the only ones!
We should let Lexus know about this setup problem... we have the exact same issue with the RSES and little kids... and getting the remote to work from the front seat to hit the IR receiver on the FRONT of the RSES is a trick while belted and ready to roll..
Check this parallel thread with the same issue:
https://www.clublexus.com/forums/sho...hreadid=105653
germeezy1
09-25-09 06:52 PM
jm0840
GX - 1st Gen (2003-2009)
06-03-09 04:41 AM
bocabailey
05-02-09 01:46 PM
NOMini4ME
09-05-05 06:26 AM
98Nav400
12-09-04 06:18 PM
Quick Reply: RSES question..
