View Poll Results: Are you experiencing the RX330 "dash rattle"
Yes - All the time
70
22.29%
Yes - Intermittent
138
43.95%
No
106
33.76%
Voters: 314. You may not vote on this poll
RX330 - Dash Rattle
Old 02-06-08, 02:54 PM
  #166
Zodiac
Zodiac's Avatar
Originally Posted by mandyfig
Good for you on those set of rims! Aren't they great? So, you have the 17" 6 spoke standard rims?
I will post the latest TSB on DAsh Rattle for 04's.
Mandyfig what's the latest TSB on the Dash Rattle for the 04 RX330? My 330 just started rattling behind the instrument cluster.
Old 02-06-08, 04:11 PM
  #167
mandyfig
mandyfig's Avatar
There's quite a few out there. Best way is to pinpoint exact location and then explain well with your service advisor. Best way is to be able to re-create in front of the tech person. I will check on my files and see if there is one specifically talking about rattle behind the cluster.
Old 02-08-08, 11:47 AM
  #168
LEXOWNER86
LEXOWNER86's Avatar
I don't have a dash rattle... thank goodness! BUT my sunroof part rattles, it seems to rattle from the edge of the sunroof to under the light and sunroof opener area. It drives me nuts! I took it to Lexus and they said they fixed it, but it still rattles, so I just bang on it. LOL!
Old 02-16-08, 10:25 AM
  #169
mandyfig
mandyfig's Avatar
You have to take it back, eventually they will fix it.
Old 03-28-08, 05:38 PM
  #170
rjm
rjm's Avatar
It looks like most of the dash rattle issues are in the older model RX's. Has the problem been solved in the '08-'09 models?
Old 03-28-08, 05:57 PM
  #171
catdaddylo
catdaddylo's Avatar
I have a 2008 RX350 AWD that I bought new last month. It has a dash rattle that you can barely hear with the radio on and most of my passengers do not hear it unless I ask them to listen for it. I am going to have the dealer address the problem when I take my RX in for the 5000 mile complimentary oil change. I am getting used to it as it seems I am the only one that really notices it. It's not real loud and it is not a consistent rattle, just when the road is a little bumpy. If this car was several years old I probably would not notice it but on a brand new Lexus, I expect it to be as quiet as my 2005 ES330 and 2000 BMW Z3 which it is not.
Old 07-08-09, 12:13 PM
  #172
lexic
lexic's Avatar
Originally Posted by fw1
... I noticed a 'ticking' noise from the driver side a/c vent and dash area right behind the steering wheel. Every minute or so, it will do a 'tick'. To me it definitely seems that the a/c vent piece and the odometer piece is not properly sealed with the dashboard. ...
fw1, have you fixed it?
I have rattle which sounds like you described. It is not easy ro repro. I hear it every morning. I went to lexus dealership but they where not able to fix it. They say "It is not consistent and loud enough to find the source".
I found it comes louder on engine's 1200-1400 rpm. It is typical idle rpm when you start it at morning. It is definitely depended on engine's rpm. It becomes louder when i go downhill with breaking by engine (same 1200-1400 rpm)
Old 07-08-09, 12:48 PM
  #173
xfirechief
xfirechief's Avatar
WOW, I thought this subject was layed to rest a long time ago.
If you read back U will see that this has been a problem that Lexus is aware of & has tried many fixes. Take it to a dealer & have let them go for it. Most of us did just that. I finally got rid of it by trading our '04 in for a '09.
Old 07-08-09, 01:22 PM
  #174
mandyfig
mandyfig's Avatar
Ticking noise could be the injectors...had mine done and it went away....might be looking at the wrong thing.
Old 07-08-09, 01:25 PM
  #175
mandyfig
mandyfig's Avatar
Trying to describe a problem is so hard. Then you add a screwy Service advisor, you are toast. You have to learn how to describe the problem. I read a list of typical descriptions of problems from an Acura service manual. In the list, the common descriptions of the problems are explained. If the SA does not hear one of them, they automatically rule you out. I will see if i can find that list and I will post it here.
Old 07-08-09, 01:26 PM
  #176
mandyfig
mandyfig's Avatar
The Haynes Repair Manual had this list, too, I remember....
Old 07-08-09, 02:38 PM
  #177
lexic
lexic's Avatar
It is good idea to check injectors. I'll consider it.
Lexus dealer... I've been there twice with the problem. I was able to repro. But they where not able to find source. They covered cords in that area but it does not work. Mechanic said the source could be even outside...
Btw, how easy to remove driver's vent piece? It is just small plastic part at the corner of left side.
I'm going to buy Haynes Repair Manual today...
Old 07-08-09, 03:55 PM
  #178
DaveJ
DaveJ's Avatar
I finally gave up on repairing the dash noises for my '06 GS300. There was no end to it. I finally sold the car and bought a Ford with no dash noises.
Old 05-30-13, 07:07 PM
  #179
JONIS250
JONIS250's Avatar
Default Dash rattle and makes weird noise
I have a 2004RX330 made in Japan and recently i experience the dash rattle and noise. I am not the first owner so not sure whether the first own had it fix or not. Now the car is out of warranty, does anyone know how much it would cost to have the rattle fixed?
Old 05-30-13, 07:11 PM
  #180
JONIS250
JONIS250's Avatar
Originally Posted by RXOwner
I dropped off my 330 at the dealer to fix the rattle coming from the area where the windshield defroster vents are.
The service advisor said that, with these models, there were known problems with the insulation between the dash and the windshield.
At any rate, they have it now and I'm driving a new loaner vehicle, an RX 350 with only 900 miles on it.
Did they fix the rattle?
bsims_01
12-05-20 12:28 PM
Jjman79
04-06-14 12:45 PM
ekrueger
11-03-10 05:49 AM
phatz
03-14-10 05:08 PM
vertcobra9
03-08-07 10:06 AM
Quick Reply: RX330 - Dash Rattle
