View Poll Results: Are you experiencing the RX330 "dash rattle"
Yes - All the time
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
70
22.29%
Yes - Intermittent
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
138
43.95%
No
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
106
33.76%
Voters: 314. You may not vote on this poll
RX330 - Dash Rattle
#106
#109
#110
I had a squeek/creaking noise coming from the rear, and found it to be the plastic cargo screen latch that touches the rear hatch when the hatch is closed. Applied some grease to the contact points, and noise is gone.
#114
certain models on RX330s i dunno about rx350s , had a TSB for weather stripping. weather stripping is a rubber gasket thing that goes above the doors. they had problems with it getting loose and making wind noise. i cnt really hear it in my car but my mechanic says he can hear it, so im gonna have them fix it.
#116
#117
I have started to hear noise from the Glove Box.....anybody else? If I push it, it stops....but it is not constant...in and out....
#119
I have a very odd intermittent dash rattle. I have an 2004 RX330. My dash rattle comes from around the Navigation screen. I only hear it on roads that are bumpy. It sounds like the Navigation system is loose and rattling. The road has to have a lot of small bumps. It is not all of the time so it isn't terrible, but it can be annoying.
I also had a squeak that I fixed in the back seat. The back passenger seat needed to be tightened down to the rail. After I tightened all of the bolts, the sqeak was gone for good.
Here is an odd one. I was sitting (for the first time) in the back seat and I leaned the seat back to rest. I was hearing (only on the highway) a sound like something was flapping by small back window. It sounded like a small piece of string that was flapping and hitting near the window. The seals are all fine. Any ideas?
#120
The rattles and squeeks are back.....
