1-touch sunroof is no longer 1-touch
I noticed today that the sunroof wouldn't open or close with the "one-touch" like it's supposed to. I had to hold the switch the whole time to open/close it. Is there a way to reset it?
When that happened to me:
1) Open the moonroof.
2) Hold the switch to open for 5 secs.
3) Close the moonroof.
4) Hold the switch to close for 5 secs.
Try repeating it maybe 1 more time, and it should reset. Do the same for the tilt feature.
There is probably detailed instructions in the manual, but all I did was remember how my salesman set it (just played with it). If not, take it in to the dealer.
One-Touch
To re-initialize the moonroof: (from the RX330 pre-delivery process, TSIB # PG002-03)
1. Turn ignition to "on".
2. Operate the moonroof by pressing and holding the button to:
a. fully closed
b. full tilt up
c. full tilt down
d. full slide open
e. full slide closed
a. fully closed
b. full tilt up
c. full tilt down
d. full slide open
wow, it's that many steps! hmm, i thought it was just hold the tilt up for 5 sec after it is tilted up, then it would tilt down a little, then it's ok. Well, i guess it's different for all the models?!?!
llocur
06-20-15 07:54 PM
