RX330 questions
Out of Warranty
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
The reason **excuse** I always got for GM putting those skinny tires on their K20 (3/4 ton, 4WD) Suburbans was that they were equipped for snow country where the high load per sq inch resulted in the tire pressing through the surface powder to the firmer snow beneath. Yeah. I question that one too!
Originally posted by noosense00
My knowledge of tires is not the greatest. How come a wider tire would result in worse traction in wet/snowy conditions? Wouldn't traction be better since a wider tire would have more contact on the ground?
Originally posted by Booyah
The AWD has a 50/50 front rear split all the time!! It uses the brakes and and plays with the power a little(VDC) when the situations gets slipery in snow.
an added option. I don't see it on my RX330. Am I correcct in assuming that the included VSC/Trac
control is the "improved" replacement ?
