Front brake rubs when wet
Old 08-22-04, 06:24 PM
johnac
johnac's Avatar
Default Front brake rubs when wet
After washing my 2004 RX330, the left front disc brake makes a metallic rubbing noise when the wheel is turned and the brake applied.
Anyone else, and any ideas what this is?
Old 08-22-04, 07:37 PM
rxdriver
rxdriver's Avatar
Both my RX300 and 330 have made squeaking noises when the brakes are applied while they are wet. Noise doesn't seem to change with wear / mileage. Doesn't always happen, either... a car wash makes it more likely, and a very humid, rainy or snowy day can do it, too.
I think it's due to high metallic content in the brake pads.
It's always stopped after things dry out. Using the brakes a couple of times generates enough heat to dry up the moisture.
Old 08-22-04, 11:00 PM
HarrierAWD
HarrierAWD's Avatar
That's typical for very wet brake. Nothing to worry about. Lightly apply the brake to dry the rotors.
If you are washing your Lexus at home, drive it around to dry up the rotors and brakes before putting it back to the garage.
Old 08-23-04, 03:04 AM
ederny
ederny's Avatar
Default Washing at home
Another thing you may notice is if washing at home, once the vehicle is dried and started, moved the ten feet into the garage and left overnight, is the rotors will get a thin coating of rust on the raw exposed rotor surface. this coating of rust can be heard making noise as the rotors turn when backing out. A couple applications of the brakes and the rotor surfaces are again smooth.
GoHuskers
NX - 1st Gen (2015-2021)
08-30-17 07:37 AM
Deathrow23
Suspension and Brakes
06-01-13 02:55 PM
I8ABMR
04-27-12 10:18 AM
daweeze02
11-14-09 09:39 PM
Quick Reply: Front brake rubs when wet
